Hi all
As per other recent posts, I recently had a flood. We have decided to lay laminate flooring in the through lounge and hall way. I plan to separate the hallway and lounges and treat as two separate jobs, however the through lounge is still 45m2 approx. I've laid quite a bit of flooring in the past but mainly bedrooms or friends smaller lounge, I've never tackled an area as large as this one.
There is currently floor boards down which are in fairly good condition and flat. I plan to run the laminate the length of the room to try to give a longer feel and "join" the two rooms more into one.
Generally I'm thinking (other then nerves) that if i have laid flooring before i should be fine, it's just a bigger area which will take longer. I am thinking i need to be particularly strict on the gaps i leave round the edge and around fittings to allow for expansion, particularly due to the large size.
Is there anything else i need to think about when scaling up to a larger job when it comes to laminate flooring?
Any advice much appreciated!
Many thanks
Ste
Many thanks
Ste
