Hi all. I'm working out what I'm going to do for a retaining wall in the garden (basically the garden is ~1m above the house level and I'm going to take a chunk out (removing existing retaining wall) and make a patio area. The retaining wall will be in two sections; the longest about 4.5m of which 2.5 will be straight and the rest a gentle curve, adding strength. The wall will be about 1.2m high, and the retained soil is clay.
My original plan was to use dense concrete blocks for the wall with suitable foundations, backfill, drainage etc (I've been doing my research!). However I've come across a couple of interlock block systems such as Allan Block (Info is here).
These are about 3x the cost of the concrete blocks I was looking at, but the walls have a simpler construction method and are 'ready finished' so there will be no need to render etc to make the finished wall look nice.
Does anyone have any experience of these systems, or any good advice on whether it's a good or bad idea?
Thanks in advance
Thanks in advance
