Any way to detect current in a wire without exposing it?
4 Nov 2006
Bournemouth
Afternoon,
Has anyone ever seen a device or method that can tell you how much power is running through a cable? -Without cutting the casing etc.
I know that you can get wire detectors, but is there anything that is a bit more advanced. I'm looking to research the whole area.
More of a research/discussion post.
cheers
Yes.
Do you mean for one-off measurements using a clamp meter, or permanent monitoring using a current transformer?
When you say "cable" do you mean a cable with both Phase and Neutral conductors in the same sheath, or do you mean a single conductor like a meter tail?
Current transformers (which is what a clamp meter uses too) only work with single conductors, as otherwise the magnetic fields cancel out due to current flowing in opposite directions in the P and N conductors.
