Anyone 'young' enough to identify this shower mixer cartridge and figure out removal?
14 Oct 2013
London
Hi all,
Recently moved into a circa 40 year old house (mid to late 80s) and a couple of weeks in, the handle to our shower broke off mid-shower.
The only way to switch it off was to isolate it from the cold/hot pump feeds.
This could be the original or in the last 20 odd years old
After cutting through tons of silicon, this is what we are left with - 99% its the cartridge as the on/off motion (lift/push) is completely floppy and the temp (left/right) while resistant, does nothing.
Problem is no one can identify it and more importantly, figure out removal of it to see if a replacement exists.
The only one clue is, it does state Ideal Standard in the middle.
Anyone remember this type of mixer and remember how to remove?
Thanks in advance!
looks like an old sirrus or mira mixer from that era mate. usually there's a brass retaining collar or circlip hidden behind that shroud once you ease it off, spray plenty of plusgas round the threads first and let it soak overnight or you'll twist the pipework behind the wall trying to force it. if the body's fused solid it's usually less headache biting the bullet and fitting a modern thermostatic bar valve with an easy-fit kit rather than hunting 40 year old brass spares.
Thanks all
We are getting quotes in to replace the entire bathroom so this was more a stop gap just so we were not reliant on the same unit in another shower
I assumed it was just the central part that would pop out to reveal the cartridge but from what I am reading here, the whole brass body is the cartridge hence the comments about bigger hole and connections either side?
Thanks again
... spray plenty of plusgas round the threads first and let it soak overnight
Top tip. Almost every other post I read on various forums suggest using WD40. Really winds me up and clearly shows they don't know what the "WD" stand for :unsure:
Yes I know WD40 make penetrating products but well done for using the correct stuff!
Thanks all
Thanks again
Much sadness is caused when a mixer or pipes have been recessed into a wall and tiled over, and the wall has to be smashed apart when there is a fault or leak.
The very high quality Aqualisa round mixers have been designed so that, if correctly fitted, the cartridge can be replaced without disturbing the tiles.
Though I still prefer a surface mixer with chromed pipes.
