Anything cheaper or better than Watertite?
20 Jan 2007
I plan on using Watertite on the walls of a moldy basement but it costs £65 / 5kg. I can see a few alternatives like Technoseal but they don't advertise as anti-mold. I also found a few negative reviews of Watertite.
The floor is made of stone slabs that are always damp. Replacing the it isn't an option so I believe I'm supposed to just seal it with polyurethane or epoxy rather than tanking slurry.
The walls aren't running with water either, so I'm under the impression that tanking slurry is also overkill for the walls.
It's a small basement and only to be used for storage and occasional diy.
20 Jan 2007
Thanks. I'd ruled out tanking because I thought a fillet seal isn't possible with a stone floor. I was just going to use Watertite sealant where the wall meets the floor.
What would happen if I did this? Will the fillet seal resist crumbling due to water under the slabs?
20 Jan 2007
I know that's what I'm supposed to use for the join to the floor but I was told I can't use tanking slurry over the stone slabs because they'll just crumble. Will the fillet seal crumble if it's next to the slabs and epoxy?
12 Jan 2014
Essex
tank behind the fillet, and epoxy upto the wall behind the fillet
you shouldnt tank or epoxy on top of the fillet
