Chirpy,
Finally got your drawings up.. If it was us we would walk away, until somebody provided some decent working drawings, as the present drawings are just not workable or practical.
Take section first, Shows joists running front to back, but no partition or steel in centre to support this span. Gives one measurement only, 2400 storey height, Will come back to this later.
Side Elevation.
Left hand side of pair of doors shows 300 cavity wall with 90 degree return towards flank wall of house then 90 degree internal return to rear wall of extension. Is this all cavity wall and if so what is it sitting on? Or if it is studwork, what is it sitting on? The rectangle section of the first floor joist that will be left open, How is this to be waterproofed? Back wall of extrusion shows a 300 cav wall with plate at 2400?.on both existing house and new extension. It is just not possible to do this as you will not be able to fit gutter to extension or be able to get cover flashing for tiles to roof extension under existing house verge. The plate for the extension needs to be 300 lower than house to get gutter and cover flashing in and this will give you a storey height of 2100, unless you bolt ceiling joists to rear rafters to form a raised tie. Just had another butchers at the comic and it would appear dormer ceiling is at 2100 same height as door frame and back plate is also at 2100,. even though the section states 2400 Nothing makes sense. Remember Lad, never scale, only work to measurements With regard to main saltbox, as ridge is off set to return wall left hand side of doors, you will have a great big hole up there with nothing to fix your finish to,
Forgot to say it would appear that front curtain wall under dormer appears to be in studwork..
See no problem with dormer, but due to lack of information you may just need a treble up the sides.
The easy way to do a salt box Chirpy is to either put in hefty purlin, flitch beam or steel, whether you need it or not. Two reasons. 1. Hang or place joists on beam to relieve load on rafters, and to give you a working platform for top ridge and 2. split long rafters into two to make it more easy to pitch. We know it means an extra birds mouth and birds beak per rafter, but at the end of the day is much more quicker.
Without further info, that is about all the help we can give you. Not trying to teach you to suck eggs, But if you have bought Trada tables and want any help with them, then let us know. We work out our length of rafters with natural secants, but Ralph Goss Roofing Ready Reckoner is about the best you can buy, if you have not got it already.
If you want to know an easy way to work out pitch, rise, run and slope then let me know.
See yer oldun
