I've recently had vinyl sheet flooring (Avenue Expressions) installed in my upstairs bathroom. (The installer laid plywood sheet down first.) When he'd finished and called me to inspect, I saw some small air bubbles in the middle. He said not to worry, they'd disappear in a couple of hours as the vinyl stretched. They didn't and I called him back the day after. He turned up, worked on them with a smoother but I could see that there was no difference. His reply was, leave it for a week or so, if there was no change, he'd come and relay the flooring--whether he meant he'd relay with NEW vinyl or just pull up the old sheet and reglue, I don't know.
While I wait for developments, I've noticed that the whole flooring looks and feels a little "dimpley". The patch I had originally noticed (because the light from the window shines straight on it) just has bigger dimples. Yet the material itself (I still have the offcuts) is perfectly flat. The dimples have to be air bubbles.
Should the floor indeed be as flat as the samples in the shop (or my offcuts) or are these dimples to be expected?
