My new house was built in 1960 and as a result the lighting circuits have no CPC (earth) connection. Quotes for a rewire have been in the order of £1500 which we cannot afford (also we have just redecorated).
Had a sparky do a survey and confirmed the obvious - either rewire or use double insulated light fittings and switches. The previous owner has not done this and all lights are currently class 1 - ie should be earthed but are not...
We're going to install new double insulated fixtures in the same locations. However the living room only has 3 x wall lights (currently with 120W halogen in each) and despite looking on several "double insulated fittings" websites I cant find any fittings that would put out enough light (high enough wattage) and be a reasonable price
I plan on using all-plastic batten lamp holders (wall mounted at over 2.0m to replace the old fittings) with a separate wall mounted lamp shade over this (not connected in any way to the batten holder).
However, on looking through all technical specs for MK, Crabtree etc and googling the topic it seems most batten holders have an earthing terminal and none say "class 2 compliant / double insulated". I have seen mixed accounts from electricians on forums on whether all plastic battens (with HO skirt) are Class 2 compliant.
Three questions:
1 - Is the earthing terminal on plastic batten holders just there because most lighting circuits these days will have an earth wire to connect or is it "needed" (ie class 1)?
2 - Are they therefore class 2 compliant (double insulated) even if not explicitly stated?
3 - Is what I propose (plastic batten holder and separate shade) within the regs (NB it is NOT in a bathroom / kitchen etc as mentioned).
Many thanks,
Joe
Three questions:
Many thanks,
Joe
