Are telephone cables insulated?
17 May 2013
My house has a dedicated telephone wire strung about 100m up our drive. In one place it is hung off a bracket on a handy tree but in other I note it is resting (lightly) on a branch or two. There's no stress on the cable and I don't think these branches will grow in such a way as to cause any, but I am unsure if this will degrade the quality of service as I don't know if the cable is insulated.
Can anyone tell me? Keeping the wire free of serious obstruction is clearly something I (unless it's OpenReach's job?) have to keep on top of but how critical is it the wire is totally clear of the slightest contact with anything?
It will be 10b dropwire....
http://www.btcables.com/documents/CW1411-Dropwire-10B.pdf
The poly-ethylene outer jacket could be abraded by the branches over time, so you should keep them away, or water will get in, then the trouble will start!
They can take a fair amount of tension, because there are steel wires in there with the copper ones for exactly that purpose.
10b dropwire
2 pairs, Green/Black & Orange/Brown
The Yellows are the Steel
OK so in theory the cable can lie on the ground and still work, but I need to be wary of abrasion especially against a tree branch where there will be constant motion?
Presumably if it's a tree on my land, it's my responsibility? What happens if the cable should fray to the point of failure due to me not noticing a problem branch (it basically travels through a small wood and is quite hard to follow)?
