Are tie bars necessary in my Conservatory?
8 Dec 2009
Bedfordshire
Hi. I have just had a 4m x 4m Victorian style conservatory built. Brick dwarf wall, uPVC coated aluminium frame with K glass double glazing and an aluminium framed, 30-degree pitched roof with uPVC capping. The roofing material is polycarbonate, but I am assured that the frame will support a glass roof if required at a later date. (Crawling on the roof is highly unlikely given its material, and the roof has survived high autumn winds without missing a beat). So unless and until I install a glass roof, I would like to omit the Tie-bar inside, which is pig ugly! Is this safe? Many thanks
The tie bar is there to provide additional support for the roof in extreme conditions under the influence of wind & snow etc. (although we don’t seem to get much of that these days) & transmit the roof loads vertically down through the ring beam. Remove the tie bar & the roof will tend to splay, transmitting side loads into the ring beam which it is not designed for; you could end up with leaks or, at worst, the whole lot could collapse.
That bar is there for as reason dont remove it. It keeps the roof together as well as to help it from pulling apart, it is structual, not just to look pretty.
You wouldnt go into your roof and start removing trusses would you. :wink:
Sorry for delay - been traveling on biz. Thanks to Richard C. for the detailed response. Note to rm2000: so do you advise that I restore all the roof trusses I removed to mke room for my home cinema then? :lol:
