could be mod valve not regulating, and the dhw thermistor could be faulty, burner pressure not correct,pepboycie said:My water from taps and shower is boiling hot and does not get cooler when I change temperature setting on boiler- any ideas??
thanks
i have had this happen to me before on a styx (ariston) combi. strange how the pressure alters wothout no one touching it itfela kuti said:Have fixed the boiler now.
The problem was that the burner was not modulating and leading to the water being heated to rapidly with no chance for the thermistor to react and control dhw.
On return i rechecked burner pressures high and low,there was no flame on the low setting with the leads to the modreg disconnected,the boiler went straight to lockout.
Adjusting the low pressure screw i managed to get a flame and set min burner pressure.the boiler now works properly again.
Somehow the min pressure altered?
Thanks nick
