Ariston Eurocombi. Hot water but no CH
29 Nov 2008
Glasgow
I had a leaking overflow which was losing pressure daily as soon as the CH was off. I had already run slicone through the system and also am in a top floor flat so knew if there was a significant leak it would have become apparant.
I pumped air into the expansion vessel and increased the pressure to 1.5 bar. I released the expansion vessel water through the CH return pipe until the pressure reached zero. This water was clear. I repeated to get more air in the vessel but this time the water was very dirty.
The leak from the overflow has stopped, the pressure has stayed constant.
However when I switch on the CH it fires up but only the first 5-10cm of the CH flow pipe gets really hot and that's it, so effectively I have no CH.
The hot water works absolutely fine.
Does anyone have any suggestions? All help gratefully recieved.
Thanks in advance
Is it possible that the dirty water that came out throught the CH return pipe has affected my circulation pump?
If so can it be reprimed?
