Hi
looking for some guidance i have a genus 23 miffi for the last month the hot water has been running hot then warm until last week i final had no hot water the diverter valve diaphragm had a hole in it, i change this and also the heat exchanger on the recomendation that this may have been blocking up causing the flame to turn on and of whilst running the hot water.My problem now is that with the boiler set on summer mode the boiler does not fire up for hot water nor does it in winter mode,but if the central heating is on i have hot water the flame is still cutting out every five minutes or so unless i open up a cold water tap and run that as well any ideas where to go with this would be gratefully recieved
Cheers
Ian
Cheers
Ian
