Ariston Genus HE24 fault
9 Aug 2011
Devon
Hi, I have an Ariston Genus HE24. I was a gas engineer, and competent to do this. It has started showing 'fan error' as a fault - have checked the flue, and also the fan for movement. The fan has run intermittently and did after I removed the condensate connection, but only once. The fan does not try and run either? This is still removed and it won't now run. I am having trouble locating the air pressure switch - manual says it is where the air seperator is?
Any ideas much appreciated
Regards Bob
