ARISTON micro genus ,
8 Jan 2008
Gwent
have tried to get the boiler to work after it being turned off for two months,I have just moved house.it was working fine before,now The low water pressure light keeps coming on. i have checked pressure gauge its showing almost no pressure. i have tried to refill system with with taps ether side of the braided pipe turned on :? . it sounds like water is going in for about 15 seconds then it stops but the pressure will not increase
Are the isolating taps on the boiler flow and return (22mm pipes, end ones I think) open? Open is when the slot's at right angles to the wall, in line with the pipe.
Pump likely to be seized - remove screw, insert screwdriver and turn the shaft
Pipe to gauge very small on this model, probably blocked. 80% chance your system is full of sludge
