When I switch on the C.H. the gas ignites then goes out after a few seconds, but there is still a background noise as if a pump or fan is still running. However, if I then turn on a hot tap, the boiler ignites and heats the water, and when I turn the tap off again, the boiler goes out - as you would expect - and a few seconds later it re-ignites and heats the radiators. The water pressure is about 2 Bar, there are no faults indicated on the control panel and all radiators are set at maximum.
The boiler is only about three years old. Anyone got any ideas?
Thank
Rob
Thank
Rob
