Hello, currently have 1 out side light which is fed using 1.5mm armoured cable, i want to add another light outside.
The current light currently sits in the middle of where the 2 lights which i want to install will be. I was going to use a resin kit to bond the cable to the new cable run it to one light then back to the other. Then i came acros this ;
http://www.lamppostelectrical.co.uk...MM+2/3/4+CORE+SWA+BRANCH+JOINT+KIT/1985930450
Can i just use this to joint onto the original cable in the middle then out to the 2 new proposed lights ?
