Don't know about "paints or things" but I've skimmed over artex a few times, needs the usual "preping" but no problem. I would take it over to painting and decorating and see what them lads have to say....
Depends on the type of artex or pattern thats been used, but I skimmed over mine after using a big jumbo scraper which had a blade practically like a razor on it to scrape off all the nobbly bits
Don’t even think about it; it may look slightly better than the Artex but a total novice will make a pigs ear of skimming & those "paints & things" will identify your efforts as a total bodge forever more; it‘s never going to look right. Even worse, if you cover it all up with wallpaper the whole lot will probably come off the first time you strip it back; but you could always leave that problem for someone else if your that way inclined!
you could always just board over the artex then skim over the new board, but a mate of mine just scraped off the nobbly bits, painted it with bond it, then skimmed over it, and it looked fine.
