B
Big_Spark
Please read this piece of Astro News before reading my question below it.
Origin article can be found Here
Now my question is this, Who thinks it would be a good idea to look at the feasibility of using human technology, such as chemical rockets, to alter this asteroids orbit so that instead of missing Earth, it actually enters Earth Orbit about 36,000 miles above the surface in a Geostationary orbit?
This would then be in an excellent position for the actual study of an Asteroid in space, something we don't have the luxury of yet, but also it could be used as a Space Station. Then we could use it as a test bed for mining operations in space at the same time.
If such a plan was considered too dangerous, what about the alteration of it's orbit to cause a Lunar Impact that we could then study?
Last month was significant for the asteroid formerly known as 2004 MN4. On July 19, it lost its provisional designation and acquired its permanent number and name. The number, 99942, is the largest yet assigned to an asteroid. The name, which will delight Egyptologists and science-fiction fans alike, is Apophis.
Between July 9 and 11, astronomers Dave Tholen, Fabrizio Bernardi, and Roy Tucket took what are likely the last optical images of the asteroid before 2007. They used the 90-inch Bok Telescope at Kitt Peak National Observatory in Arizona. The same team discovered the asteroid last June.
On April 13, 2029, Apophis will pass 22,600 miles (36,350 kilometers) from Earth — so close it skirts the belt of orbiting geosynchronous satellites and will be visible to the unaided eye as a moving, magnitude 3.3, starlike point. Astronomers estimate the space rock is 1,050 feet (320 meters) across and has a striking power equivalent 850 million tons of TNT, or more than 4 times the energy released when the Indonesian volcano Krakatoa erupted in 1883.
Asteroid Apophis will pass near Earth in 2029. E. De Jong, S. Suzuki / JPL / NASA
At about the same time Tholen's team took its latest Apophis images, the Jet Propulsion Laboratory's Near Earth Object (NEO) Program Office incorporated new observational data into its calculation of the asteroid's impact risk.
The new data slightly raise the odds of an impact in the 2030s to roughly 1 in 8,000. The most probable impact scenario occurs in 2036, off the Pacific coast of North America, and carries the potential of generating a 30-foot-high tsunami that could strike southern California.
Still, while Apophis probably won't strike Earth in the foreseeable future, the asteroid will not be the same after its close encounter with our planet in 2029. Earth's gravity and the tidal forces exerted on Apophis will change it in several ways — a cosmic makeover.
First, the asteroid's orbit will be significantly altered. As things currently stand, Apophis belongs to the Aten group of asteroids, which circle the Sun inside Earth's orbit. After April 13, 2029, the rock's orbit will have changed enough to place it in the Apollo class — asteroids that actually cross Earth's orbit.
Second, the encounter with Earth will significantly alter the object's rotation rate. Recent calculations by a team led by Daniel Scheeres of the University of Michigan indicate that tides raised in Apophis by Earth's gravity could result in a lengthening of the asteroid's present 30-hour "day" by as much as 27 hours; a speed-up is also possible. The 2029 encounter will provide astronomers with their first chance to watch the disruption of an asteroid's spin state.
According to Scheeres and others, such as Dan Durda of the Southwest Research Institute, the tidal forces will strain the asteroid, causing "localized shifts" — asteroid quakes — on its surface and within its interior. If the asteroid has a lower density — less than half that of water — than astronomers now think, Apophis could be either reshaped or completely disrupted.
Apophis is the Greek name given to the Egyptian demon Apep, who was the enemy of light and order, the personification of evil and chaos. Depicted as a giant snake, Apophis/Apep attacked the Sun god Ra as he made his way through the Egyptian underworld during the evening hours. Solar eclipses were thought to be Apep's few daytime attempts to swallow Ra, who always succeeded in cutting his way out of the snake's belly. As the enemy of Ma'at, the ancient Egyptian concept of order and law, Apep represented chaos.
However, it's likely mythology wasn't the only consideration in naming Apophis. Codiscoverer Dave Tholen is known to be a fan of the TV series Stargate SG-1. The show's most persistent villain is Apophis, an alien also named for the Egyptian god.
Whether inspired by mythology or science fiction, the name seems appropriate for an object that continues to change the way astronomers think about asteroids and planetary protection.
