Attaching Insulation board to joists
17 Jun 2015
I have to put 100mm Insulation between the ceiling joist and cover the whole ceiling with 40mm insulation board.
Can I glue the 40mm boards to the wooden joists? and if so what would I use?
We partially tack the inso boards then fully fix the plasterboards through both. It is more economical to fix them in two separate layers in any case.
I agree with noseall. I'm doing the exact same thing at the moment abet with 150mm overlay with 12mm. I spoke to celotex technical and they advise just 4 screws to hold in place and then screw through plasterboard and insulation together with 60mm drywall screws (12mm insul +12.5mm plaster + 36mm into rafter.
I suppose glue would work as its a temporary hold until you fix plasterboard over. Cheaper to use screws though. And maybe a few of these:
http://www.ebay.co.uk/itm/Tile-Back...f9ff5a&pid=100011&rk=1&rkt=12&sd=201803849804
