I need to replace the automatic air vent on my Alpha 240p boiler as it has obviously been leaking, and doesn't seem to be letting the air out.
I bought a replacement that apparently is the genunine part:
http://www.hccfspares.com/PhotoViewer.aspx?Product_Auto_ID=1114838&Manufacture_Name=ALPHA
However it doesn't fit - the exisiting one looks like this:
http://www.avenuesupplies.com/index...eating+And+Drainage+Heating+Replacement+Parts
Note the old type has a bit that looks like a nut on the bottom - this fits into a recess in the pump and allows the oring to make contact. On the new one the base is just flat, but too big to fit into the recess on the pump so the o-ring is never in contact with anything.
So my question is this - can I just buy any automatic air vent, assuming it fits and is rated at the correct pressure and temp? Or is there something I am missing? The cheapest ones are only about £5!
Thanks in advance - you guys were spot on with my last problem!
Matt
Matt
