Awful Adsl signal - internal/ extension wiring issue
16 Sep 2010
Merseyside
Morning all
hopefully someone can point me in the right direction
basically a mates house has an adsl problem, he is getting a speed of 30kb
so i changed filter no effect
i then unscrewed the face plate (NT5) an plugged into the test socket - he got a speed of 5mb !! so the prob is obviously internally
i noticed that who ever installed the alarm (it has a dialler) has just twisted wires onto the blue & blue/white attached to the face plate.
removing the alarm wire increased the download speed by 300kb but still no where near 5mb when going direct to the test socket
i found one slave socket in the next room that had the bell wire connected, i removed the bell wire but there was no effect on the download speed - i then totally disconnected this slave socket but still no effect on the download speed
is it a case of tracing the sockets around the house to find them all & disconnect them one by one to find the source of interference etc?
im kinda stuck for ideas
thanks
Internal home telephone wiring and its connections are often adequate for telephones but not ADSL.
Pukka has shown an excellent method of separating the existing phone circuits at the incoming NTE5 position and providing complete filtering at the one point. This is a neat solution.
Having checked that the ADSL is satisfactory when connected via that adapted front plate, to the router, then there is an opportunity to extend the ADSL circuit from the back of the adapter to a connection point wherever it is wished to position the router. Proper telephone or Cat 5 cable is required (Not alarm cable.)
cheers all i will buy a filtered face plate
i totally missed that the extensions on the idc's on the faceplate are not in a filter!!
so buying a filtered faceplate will hopefully help loads!!!
for the alarm i will just buy a crimp on "BT" plug from maplin an shove it into the "phone" socket on the front of the faceplate
thanks all
Best to fit the alarm connection into the back IDC connectors of the face plate or an extension socket, as it discourages anyone from forgetfully disconnecting the alarm. (And saves the cost of a crimp :D )
DUAL POST ERROR
