Back to wall pan flush pipe size
2 Feb 2012
Hi there
Just picked up a cheap concealed cistern that originally came from bathstore. It has a 44mm flush pipe with a finned seal that goes into the hole in the back to wall pan
My question is, can I buy any back to wall pan off fleabay I.e. are the flush hole inlets on pans standard sizes or do I have to buy a specific bathstore pan to match the concealed cistern pipe and washer.
Sorry if this is a basic question but I have never fitted a back to wall pan before
Cheers
Not a hundred per cent sure on this question but would think that the size is standard. Whenever I've had to replace a seal it's always been a standard one from a plumber's merchant. If buying on fleabay, you could always ask the seller the question first before putting in a bid.
