Hi
I have just re-filled my heating and primary circuit and there was a problem with air traped, so i back-filled thre system from a low draincock. Water comes into the header tank and over the vent pipe and my concern now is, with the level this high, when the hot water is on this evening pumping over will happen as the level is set too high in the vent pipe. To correct this, is it done by draining a small amount again from a draincock at low level or by bailing out water from the feed tank into a bucket until the water level is low down again? thanks.
