Hey everyone I am just about finished stripping my living room and have noticed a few problems that I will need to sort before painting it.
There has been a picture rail at some point and when this was removed someone has filled it in pretty badly as it must have ripped chunks of the plaster off, most of it is sitting out from the wall and not that many dips so I am hoping I can sand this smooth, I have an orbital sander by I can get hold of a belt sander if I need to.
There was a dado rail that I have removed myself but when I did this it has removed a small bit of plaster in some parts, only a few mm deep and no more than 5cm wide.
There are some settlement cracks that look like that been previously filled with cement? It is pretty hard and is grey in colour.
Also in some points walls have been tracked and again look like they have been filled with cement but this could just been some plaster.
Most of the problems under the wallpaper I would estimate to be over 30 years old, the house is I think 70 years old and the wallpaper has been on there from before the central heating system was fitted (I think)
My plan is to buy a bag of plaster and fill all the holds and imperfections in, then sand with 120grit all over and then 220, then a matt base coat and then my top coat.
I know I should ideally get the room replastered but I am not exactly loaded and want to do as much work as I can myself, I am assuming that plaster will be pretty easy to work with in the small patches I need to use it in.
Thanks for any advice
David
David
