- Joined
- 16 Oct 2021
- Messages
- 683
- Reaction score
- 74
- Country
interesting theory. What pressure would be required to do that and why would he not have experienced this before?As said above ,mixer tap is allowing crossover ,cold water into hot pipework.
Most domestic mains pressure would be 1bar minimally,and more than enough.interesting theory. What pressure would be required to do that and why would he not have experienced this before?
I operate my cold feed @ 2.5bar and my hot water feed is 4.5bar. I use the grohe shower mixers (the simple ones with no cartridge) and on baths I use the same simple mixer (no temp control cartridge)Most domestic mains pressure would be 1bar minimally,and more than enough.
With the system fully operational ( domestic hot water in use constantly) the symptoms have probably not manifested themselves and gone unnoticed.
What happens if cold only is switched on and no hot required from kitchen tap - Under your explanation water would come out of overflow correct? I never saw that happen so I am still confisedIf cold water was constantly running into the hot distribution pipework ,of course the water level in the CWSC would rise ,to overflow level ,it won't come out the vent pipe as that is higher than the CWSC ,and bends down into it, it would back fill via the cold feed pipe which goes into the bottom of the cylinder.
Cold must only be entering hot pipework when tap is running ,with both hot and cold valves of tap open.
That is true - I follow youIf the hot valve on the tap is closed ,no cold water could enter the hot pipework,as it couldn't get past the valve.
Shamefully I bought it on amazon - Here it is https://www.amazon.co.uk/gp/product/B08XZ2KYQP/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1I didn't get to see your tap ,but try this .
Turn cold tap on full and open hot tap partially ,let water flow for 1 minute and close both taps. Then open hot tap only ,See if water flows out the tap spout.
i will try that tomorrow - dont want to try it at night when plumbing could go. i expect answer when tap open will be yes but will confirmThanks ,I assumed tap had 2 handles . With yours ,put lever in central position ( as though mixing hot and cold ) let tap run 1 min. Turn off.
Then turn lever to hot position only and turn on ,does water flow from spout ?
You are correct ,the small diameter tap tails are restrictive ,but the real issue is the low pressure ,gravity fed hot water. The cold is good is it not ?The hot water pressure was always low. With the new tap it’s dreadful. I thought that was because of the tap tails which are 10mm
The cold is good correct - I always will have gravity fed hot - What does everyone with a hot water cylinder end up doing?You are correct ,the small diameter tap tails are restrictive ,but the real issue is the low pressure ,gravity fed hot water. The cold is good is it not ?
