HW fine. Boiler fine. CH not!
Two separate valves; both motorised and working. There is no balancer valve...
Stats working and controller working.
Forced system to pump hot water around CH; removed motors from valves, manually selected CH with no H, forced both thermostats to power pump and fire boiler.
Pipe vent on feed above pump and before valves (by HW cylinder) gets very hot. as does pipe into HW cylinder. Pipe for CH starting to get warm but much cooler below valve.
Opened all downstairs rads to try to get flow (closed all upstairs rads). Hoped that some rads (or even just one) would get hot, but no.
None of the pipes at the radiators are getting warm, let alone hot.
Water is getting back to boiler as the over-temp cuts it out after a while.
Left system running all day.
Help?
Why is the water that is circulating not making any pipes warm?
Help?
