Has been a good boiler but all of a sudden it has started to make "noises and cutting out" the noise appears to be coming from the Full Sequence Ignition Device. the Full Sequence Ignition Device has been replaced with a new one (£140.00 ouch) but still the same problem occurs. It appears that when the boiler is on, the natural but small anount of vibration in the panels cause the FSID to vibrate and the inidcation is that there may be a loose electrical contact loosing its continuty. I have checked all cables and none appear to be loose.
When the boiler fires up and runs it is ok but the problem occurs frequently and with no given time setting - can run for 5 minutes or 15 mins and then it plays up - there is no conistancy
Has anyone had a similar problem or know the answer to this frustrating query.
Thanks your help in anticipation
Rfen
Rfen
