Hi! I've recently fitted several TRVs and Lockshield valves to my system and am trying to get my head around the rebalancing. I would appreciate any advice on the subject & in particular the following:
a/ Is the boiler temp setting critical?
b/ Should the bypass valve be open/closed prior to adjusting the rads?
c/ Should rad valves be open/closed before starting the operation?
d/ Should the rad, in the area of the roomstat, be on/off?
e/ What is the ideal temp difference between rad flow & return?
Thanks in advance. CP.
