- Joined
- 22 Jan 2007
- Messages
- 24,651
- Reaction score
- 3,722
- Country
Same here, rarely need to intervene.More or less, and all rads, all heat up evenly at the same time.
TRV’s can unbalance a system according to some heating expertsThat's the TRVs for you.
Take my comments with a pinch of salt but you should look to see what trvs and lockshield valves do to the system from a functional standpoint.TRV’s can unbalance a system according to some heating experts
Why?Rubbish - Balancing should still be done when TRV's are installed.
You could get away with it but it won't be as efficient.
Imagine when the system starts up after a cold night and all TRVs are open. Then the system will need to be balanced to enable each rad to correctly heat its own area.
Clearly, my statement can be challenging if you're not used to modern controls and designs, i understand that. It's not a statement of fact. It's just my reasoning of the system behaviour. You're not going to find the answers here in a well worn copy of the 1986 guide to domestic heating.Imagine when the system starts up after a cold night and all TRVs are open. Then the system will need to be balanced to enable each rad to correctly heat its own area.
Is the hope to get 12 degrees across each rad. Does anyone used temp clamps to do it?
Typical balancing issue. Work back to the boiler and open them only a quarter turn and check. Leave the problematic ones fully open.I have had all rads of and they get boiling so an air lock isn't an issue
