Balnce valve on pumped Central heating system
28 Oct 2007
I would like to check the position of my balance valve. Which has a brass cover over the square key.
It looks like a Comap C x C Gatevalve L/S Brass 15mm as seen on screw fix.
http://www.screwfix.com/app/sfd/cat...HZOCFFA?productId=56961&imageNo=null&ts=45858
Question can I remove the brass cover. I tried this morning and it started to leak a bit. Is it just like a normal gate valve with a cover?
I'm trying to avoid another plumbing disaster.............It was suggested it should be open about half way on this forum after I was concerned I altered it during a previous plumbing disaster.
Here is that post
http://www.diynot.com/forums/viewtopic.php?p=797392#797392
Cheers & TIA for any advice
John
The shield doubles as a gland seal, whcih is why they dribble if you remove it.
Open a couple of turns is usually enough.
Is it just like a normal gate valve with a cover? <<Yes
Thanks Chris
What are the affects of having the balance valve open too much or not open a little?
Cheers
John
Depends what it's connected to....
cylinder or just a bypass?
Hi Chris
The bypass seems to bypass the heater coil in the cylinder. I've just found a leak at the top heater coil connection with the cylinder which I've carefully tightened and hopefully cured (fingers legs toes crossed).
Cheers
John
