I have a Keston C40 boiler that emits loud bangs in radiator pipes from time to time. It seems to happen when the boiler is shutting off in CH mode.
I had a Keston engineer in but all he said was that the flux and return pipes were too small (22mm instead of 28mm) and that there was no point looking at anything else before this is fixed. I'm a bit skeptical as the boiler has run satisfactorily for a year with these pipes.
Before I go through the expense of upgrading the pipes (that would only be on 2-3m from the boiler to the first pipe junction anyway, can't do more), I'd rather check if the problem can come from anywhere else, like an air lock.
Any idea? Is there any manual vent in these boilers or do they went automatically?
Regards
Regards
