Hi All,
I recently bought a flat and having major problems to get the central heating/hot water system to work.
I am no DIY expert and therefore called out an 'expert' on the recomendation of a friends's friend.
He came, shook his head after inspection
and told me it needs changing several parts such as the electronic programmer switch, motor, some pipe fitting etc and quoted a price of £450. Eventhough I didn't expect such a large bill, I have had no choice but to go for it. Anyway, he fitted the new parts and now says the system needs some sort of cleaning. He is asking for another £250 to get it to work. I'm not sure even after what he says is done the system will work properly.
The current situation is as follows:
When I turn the system on, the boiler starts to fire and I can see the flames through the small glass panel at the front. However, after about 5-10 minutes, banging noices are coming from the boiler and the pipework surrounding it starts to shake. If I leave it then the system seems to cut-out automatically. Naturally, I am with no hot water at the moment and as a result cannot move in.
The boiler we have is a Potterton Netaheat 50. The boiler looks ok in outward appearance. The new control/electronic switch fitted is made by Honeywell.
The property is an ex-Council, 1 bed room, ground floor property in Hackney, London.
Can anyone help please on the way forward? After buying the property, I'm skint and therefore looking for an economical but a safe solution. Would also appreciate any local expert (genuine CORGI registered) recomendation.
Thanks in advance for your help.
Best regards,
Joel
Best regards,
Joel
