I'm hoping someone can help. I don't know much about central heating systems.
I've just installed a new boiler (Vaillant Ecotec 637) and new hot water cylinder. Previous system was vented whilst the new system is unvented.
Problem I have is when the boiler cycles to heat the radiators I hear loud banging noises in the pipes and radiators. My boiler seems to cycle 4/5 times a hour and the noise is a problem particularly when the heating goes on before I get up in the morning - no need for an alarm clock!.
I suspect the boiler is more powerful than it should be. The previous boiler was a Vaillant 28KW and it worked fine. I've added some underfloor heating in one room and increased the size of the hot water cylinder but not sure that justifies the increase to 37KW. I've played around with the power settings taking it down to 24KW but doesn't seem to make any difference. Some of the loudest radiators are the closest the the boiler so I'm wondering whether there is a flow speed issue that maybe fixed through balancing the radiators.
Any thoughts/ideas welcome.
