Base for small garden shed
8 Jan 2011
Afternoon all. I've had a quick search but can't find any threads asking the same as this.
I'm rearranging my garden, and this involves moving the shed. It's only a small shed - 4' x 6' - however I want to make a proper job of it. I also don't want to spend too much money, as I only rent the place.
Where I intend to put the shed is currently a raised flowerbed, with a 2-brick high surrounding wall. This wall is sat on 2" thick paving slabs, roughly 8" x 2' long. My intention is to remove a large amount of this wall (it forms a U shape around the garden). I'm also taking up a large amount of gravel.
I know - ideally - that the shed would stand on a concrete base/slabs laid on a sand & cement base. Could I get away with digging a bit deeper, filling this with gravel and sitting the paving slabs on top of this, and then the shed on top of that, or will I end up regretting that the first time it rains?
Thanks.
Mine was exactly like you describe and it was fine. That said it's been sat on a large pallet on the lawn for the last 6 months while I re-do the garden and it's been fine on that, too.
seems like doing it that way wouldnt be a prob...
http://www.the-shed-centre.co.uk/buying_a_shed.html
just make sure you compact the gravel really well :D
if you havent already.....check with the LL before doing anything to the garden..
Thanks for the link, had been looking for ages but hadn't found anything similar. Planning on putting a length of DPM underneath it to try and stop the bottom rotting.
Haven't checked with the LL - her words when we moved in were "do whatever you want with the garden", and given that it looked like a jungle I doubt she'll mind. The neighbours certainly don't. :p
Thanks, gives me extra peace of mind.
Not sure my fiancee would go for the pallet look, mind.
