    Dismiss Notice
Bath and sink waste into soil stack
Discussion in 'Plumbing and Central Heating' started by LaurenceCarr, 11 Jun 2021.
  1. LaurenceCarr
    LaurenceCarr
    8 Jun 2021
    2
    Thanks Received:
    Country:
    Hi all, new here.
    I’m having the back of my house rendered and want to tidy up the waste pipe work before and after.
    Currently both 1st floor sink and bathroom waste pipes go into a cast iron hopper and from there down to the gully in 2 1/2” caste iron? This is close enough to the new (ish) plastic 110mm soil stack. Can I run the sink and bath wastes to the soils stack and attach with strap bosses or use the existing in line boss 36D8AFA4-56CF-4535-A05C-B1F7D751E53C.jpeg (same level as the loo waste) ? I could then do away with the hopper and down pipe. Hope this complies with current regs. Cheers. Lozza.
  2. Baths'N'Gas
    Baths'N'Gas
    31 May 2009
    142
    Thanks Received:
    40
    Lincolnshire
    Country:
    That’s fine, I’d change the pipes to black as well, so it all matches
    • Thanks Thanks x 1
  3. Sponsored Links
  4. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,335
    Thanks Received:
    1,721
    Northamptonshire
    Country:
    Good plan, Hoppers are unsanitary things for waste pipes to go into. You wont get the lower waste into the boss on the junction, it's too high. Doesn't take much to fit a strap boss lower down, and then either common both pipes in before joining the stack, or run the basin waste to a suitable point higher up.
    • Like Like x 1
  5. LaurenceCarr
    LaurenceCarr
    8 Jun 2021
    2
    Thanks Received:
    Country:
    I was thinking of taking the sink into the existing boss and the bath to a new one. Not sure it’s a good idea to tee them into one and then into a new boss. Bath waste could cause some syphoning of the Sink waste.
    The boss is angled up at 2.5 degrees I think, so I guess waste entry has to be fairly shallow, and an elbow is required in the waste pipes to shallow the fall.
    • Like Like x 1
  6. Sponsored Links
  7. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,335
    Thanks Received:
    1,721
    Northamptonshire
    Country:
    If need be 'dog leg' the last section into the stack with a couple of 45° bends, gives you some wiggle room to get everything lined up.
    • Thanks Thanks x 1
Loading...
Share This Page
