Just installed a beautiful huge whirlppol bath. 22mm connections to side valve taps, then to a combined pop-up waste filler. Cold is supplied from an exisiting tank inthe roof, hot from the new tank installed for the new hotwater system. However, it takes for ever to fill.
any reason why i cannot fit two single impeller pumps, to provide for the bath only, or is this overkill? I was also going to fit the hot one under the bath itself, fed from the same RCd as the whirlpool pump.
Thinking that 1.2 bar would suffice - any ideas?
