I have a recently installed (3 years ago approx.) bath mixer tap (B&Q Treviso suite) that seems to have problems with flow rates. When turning the handles the flow sometimes doesn't change and a few twists back and forth are required to change the flow. This happens on hot and cold.
Also, sometimes when the taps are on, the flow just suddenly stops and it needs to be turned on and off to get flow back. Its as if something is slipping and not gripping inside.
Anyone any ideas if this can be fixed, rather than replace the whole mixer tap which will be tricky as bath is in place!
