Had a problem over the past few weeks of the bath leaking around the edge as it meets the tiles and also from the plug hole area, so taking the bath out today to fix these problems, scrape all the silicone off etc.
The bath is a Plastic fibre glass type, with the metal from and dodgy bolt feet to keep it up, can I put blocks underneath the bath between the floor and the piece of chipboard glued to the base of the bath for more support or will this cause problems?
Reason I want to do this is to reduce movement of the bath from the wall, room not square so big gaps around the bath.
Any advice appriciated,
Gareth
Gareth
