Hi all,
need some advice on my mixer tap on the bath. I have a combination boiler set at 1.5 bar, and pressure outlet is very good when the tap is in use but when using the shower hose and set the temp just about right, after a while the temp fluctuates between hot and cold and basically does not regulate. Some days its fine and works fine and some days the water even dribbles out of the showerhead as if no water in pipework or lack of pressure and then boiler pressure checked and is ok, this is confusing....What can I do??
