Hi, just a quick piece of advice needed.
I'm fitting a new bathroom suite. The boiler is a combi so everything is supplied with 15mm.
But due to awkward fitting I'll have to use flexi to connect the bath taps before pushing it into position (Roll top bath with taps in middle against the wall).
My worry is the reduced bore of 15mm flexi pipes will mean the bath will take an age to fill.
Would I be better of using 22mm flexi pipes to short lengths of 22mm reduced to the 15mm supply pipes?
Thanks in advance
Thanks in advance
