Bath Tap Cold Water Flow trcikles
8 Nov 2006
London
Hi All
I had new bath taps fitted approx 2 years ago, now over time the cold water tap flow rate has slowly diminished to near enough a trickle, no plumbing work has ever been done sine the taps were installed. PLease could you advise what the problem maybe and its cure? Any help would be gratefully accepted. many thanks in advance.
Hi All
Does anybody have any ideas as to why the Cold Water Tap flow has slowly diminished to a trickle? Many Thanks.
Maybe the tap washer may need changing or a supply problem.
Try swopping the taps over and see if the problem is with the tap or supply. :D
