Hot water comes out very slowly - all other upstairs hot taps ok - have tried attaching hose to it from downstairs cold tap and blasting back but only causes temp cure
I've got a similar issue, although this has only been noticable for the past 3 to 4 weeks, so I guess it would be something wrong with the tap as pressure is fine on all other hot taps in the house, and yes we have a cold water tank in the loft.
