We are replacing our bathroom fittings. Everything is working OK except the basin waste which is leaking. We think the leak originates from the fact that there is space between the sink (the plug hole) and the side of the waste. Does anyone know if sealant/grease or anything else should be used when fitting a waste (other than the seal supplied with the waste). Thank you.
