Hi All,
I am doing some DIY on my bathroom... firstly I have replaced the main light with a nice 3-spot halogen (all working) and am now on to the final job - replaing the extractor fan.
The original DID work many moons ago but just started hanging off the wall, making a god-awful noise and then generally died. As such, I know at some point the connections must have work.
However... move on and I have now removed the fan and am left with 4 wires:
Red - perm. live
Blue - neutral
Yellow - switched live
Green / yellow - earth
1) Is the above summary of what the wires are correct?
2) If so, I wire up my new 230v extractor fan (with terminals N, L, L1 - no need for earth according to manufacturer). I turn the light siwtch on and... nothing.
Now I next start to think maybe a wire has become loose somewhere. So I got a circuit tester and held the probes against:
blue / red - nothing
blue / yellow -nothing
red / yellow - connection (although this test makes no sense in my mind)
Now.. I did do the tests above with the consumer unit completely off so no power is going to anywhere in my flat... but I assume that's what you have to do unless you want to fry?!
So... am I doing something wrong or has a connection come loose somewhere? If it's the latter, would I be right in thinking all three of the wires to the fan probably come from my ceiling rose? If so I might check there to see if something has come unconnected.
Your thoughts, comments and warnings of "stop.. you are about to kill yourself" most welcome.
Thanks,
Ben.
Red - perm. live
Blue - neutral
Thanks,
Ben.
