Bathroom extractor fan Help
25 Jan 2017
I have an existing Extractor that goes from the bathroom ceiling into the loft. I plan on taking this out and putting a new one on the wall going straight outside. I am wanting a quiet extractor fan that runs of its own switch. Not of a PIR or Timer with the lights. I will have a double switch on the outside wall one for the fan and the other for the lights.
Does anyone have a recommendation for a good fan don't want to spend over £50. I have shopped around but am unsure on what I need to buy as I want to wire it into a switch.
If your switch has a live and a neutral at it then you can wire in any fan you like, if not you would have to take a neutral from somewhere safe and run a new switch wire. Probably easier to look for one with a pull switch on it. That said its more a matter of what you want. It tends to be that as the price of the fan goes up the fetaure set doe too. So a On/Off fan is cheapest followed by a timer, then pir then humidity etc. You just need to look for a quiet on/off fan. Of course if you havent got a opening window etc. etc. then if won't comply with BS I mean BR but thats up to you.
All the best.
J
Thank you for your help I am going to inspect the existing fan and ducting in the loft and probably re duct and replace the fan the existing fan is a pull cord but has a main switch on the outside of the bathroom wall but it near the ceiling.
