Hi again,
I've been sorting out the loft, removing boards, replacing the upstairs lights, and laying loft insulation. It's horrible itchy work, so I don't really want to go up there again any time soon; a good time to do anything else I might need to get done. This leads to... an extractor fan in the bathroom.
I figured that a ceiling-mounted unit running off the lighting circuit was a good way to go. I'm not sure if it's going to be on a timer or humidity sensor yet, but my main issue is where to vent the air. I thought the soffits would be ideal, but they are far too narrow to take a 100mm vent - so I support I'm left with either the fascia above the soffits, or through the tiles.
I think the fascia is just PCV, but there might be some wood behind it. It's a dropped fascia, so getting to it from the inside is going to be a nightmare. Would a vent tile be the best way to go? I'd probably need to hire a roofer to install the tile.
My other concerns are draughts coming back through the vent and into the bathroom, so would I need a vent with flaps to only open against the force of outward extractor fan air? I assume one normally mounts the fans to a rafter, then makes sure the pipe angles downwards to the vent, to stop water ingress or condensation?
View media item 68560
Bit of a long one; sorry!
