Bathroom Extractor Fan
  • Thread starter Thread starter tullibody
  • Start date Start date
T
tullibody
I am going to fit an extractor fan through the cieling and out of the roof, as the walls are to thick. I have purchased an unswitched 13 Amp connection unit, I take it this goes before the light switch. It is a 6 nterminal connection, 2 Live 2 Neutral, 2 Earth. the fan has three terminals on it, 1 Neutral 2 Switched Live 3 Permanent Live. Does the switched live come from the light or the switch.
Many thanks
you should really have a tripple pole isolator, not an fcu, as you will be taking it from the lighting cct.
all your connections can be taken from where existing light connects
the normal way is to take all three connections from the light via a tripple pole isolator
a lot of fan makers say thier fans should be fused down at 3A but do not provide decent instructions on how to do this most sparkys done bother but if you wan't to do this the options boil down too
1: fuse the feed to the lighting pendant unit
2: use grid modules
3: use a DP switch to make the fan switching system totally seperate from the light one even though they are on the same physical switch
2: use grid modules
My light switch is outside the bathroom, can I still fit the three pole fan isolator.
Many thanks : :lol:
