Hi Guys,
I am after some advice / clarification with my bathroom extractor fan installation, I have two sparkie mates who both have over 30 years in the game and both own large firms etc so both have great credentials; I am being told two different things though. I have bought an EnviroVent 100mm Fan unit with Humidistat. I have recently lowered my bathroom celling (newly plastered) and fitted some 240v spots, One is telling me I need to chase up the wall (which “should” be 150mm deep, it will never be… maybe 50mm with some galvanised trunking) into the false celling and fish a 3core & earth to my first spot light and if I want it isolated (which I must to conform to building regs… Pfft) then another cable to an isolator, well I didn’t want to cut into the new celling so my options are to A) try and fish the cables from the spot holes Or B) smash down from the loft though the original ceiling and work from there.
My other mate is telling me the same BUT with another option… I can run a cable from my fan to the consumer unit, which is directly below my bathroom, and then from the consumer unit to my bathroom light switch were he can either A) change my 2 gang switch to a 3 gang and have my bathroom fan on its own circuit on the CU with an override switch on the wall OR B) same as above but add an iso switch rather than using the 3 gang.
I have already ran the cables from my fan to the consumer unit and from the wall switch to the consumer unit, I have also trunked and replasterd!
Do I NEED to redo this?
Thanks all.
Thanks all.
