My boyfriend has just laid granite tiles on our bathroom floor, but the tiles have started to raise up into a peak along two of the grout lines, which has caused major slopes in the floor. None of the tiles or grout have cracked as yet, the tiles haven't become loose and there's no sign of movement in them, although the floor has started to creak. Does anyone know what could have caused this to happen?
The tiles were laid over 6mm ply, which was nailed to the floor boards and the tiles were fixed with flexible adhesive.
I've read that the ply should be 12mm thick and water resistant and resin bonded, is this true?
I've also heard that the ply should be screwed down, not nailed down, is this also true?
We've now got to take the tiles up and relay them, so any advice would be gratefully received.
Thank you in advance.
